Power to the fuel pump
(In Topic #117727)
When does power come on to the fuel pump, when ignition is turned on ? My 1980 GTI died on me the other day, there was right before, some cutting out or misfire, and then nothing more? I now have tested the fuel pump out of the car, and it spins nicely? But there is not coming power to the pump when I turn the key to ignition? I have read on this great forum, that it is possible to test if the relay is damaged, but I don?t have any relay that have 2 wide spades, there is one small, and the rest I the same size?
This is the kind of relay i can find..??
http://www.autopartswarehouse.com/basket.php?add_item_id=11351106
When the engine is cold, I am able to start it, but I only turns for a short time, maybe about 10 sek.
Do this car have a liftpump in the fueltank also..?
Regards..
Christian
Life Member
dubboy said
Bridge the relay with 2 male spades, heavy duty switch and 8A fuse to test the pump.
There are no lift pumps in any GTi hatchback
What contacts to brigde ? As i remember is there 5 or 6 terminals on the relay..
not all fuel pump relays make the pump run for a few seconds with ignition, but it should always run the pump when the engien is turning over on the starter motor. some relays have a fuse built in for the pump, so start there.
rubjonny said
righto, jump pins 30 and 87
That made it start up, not runing great, but the pump is runing… New relay in the mail..
Thanks Christian
Where does the signal to the relay come from, ign, coil or the rewcounter.. The pump is running if I bridge the to large terminals, but there comes no power to it when I crank the engine…
Is it possible to measure if the signal is present in any way ??
And does the MK1 have any other known problems that could cause the lag of power to the pump ??
Christian
