POWER HOOD
(In Topic #83213)
POWER HOOD
The T shaped screw is accessible through a hole in the pasenger side card inside the boot.
See it you can hear the pump working ok. It should be a bit noisy but would be able to tell if its straining as it would sound like it is.
The same T shaped screw when loosened enables the hood to me raised and lowered manually. Its recommended that 2 people raise the hood manually though as its heavy and the frame is more likely to get bent if just lifted from one side.
Cheers,
Ross
P.S. Using Caps Lock is considered as SHOUTING on forums! 8O :wink:
cheers for that sorry about caps lock learning all the timeRoss said
I've never had a problem with my power hood touch wood, so I cant really comment. Although aparrently a common issue that can stop the hood working is if the T shaped bleed screw on the pump itself isn't fully tightened. You need to have a play and see if it can be easily resolved.
Cheers,
Ross
Bought the car on saturday and drove back up to scotland with no problems it was a dream to drive.The auto electrician looked at it tonight and it was a faulty relay right enough and also there was a problem at the fuse box which he sorted as well.Thanks for all replysRoss said
No probs at all matey, welcome to the club
