Please help
(In Topic #142101)
Please help
Hi
Recently bought clipper cabrio, now horn sounds when I turn or indicate, this only started today after I had sounded horn
John
Clipper Cabrio 1990
Clipper Cabrio 1990
Park with the front wheels dead straight.
remove steering wheel horn pad.
Undo the big nut and pull steering wheel off.
You will see a little copper tab, this connects to the horn ring on the steering wheel, what can happen is that the tab can get pushed down and shorts out on the lower screw that holds the indicator stalk assembly in place.
Bend the tab up and stick some insulation over the screw head.
This is waht happened to mine..
Hope that helps.
Chortle
Hope that helps.
Chortle
Thanks I'll give that a go and let u know how I get on….
John
Clipper Cabrio 1990
Clipper Cabrio 1990
disconnect the wires that come to the horn pad too..
All sorted thanks again!!
John
Clipper Cabrio 1990
Clipper Cabrio 1990
Was the tab shorting on the screw?
why is everyone so helpful?
If you can read this, thank a teacher,
If its in English, thank a soldier.
A soldier fights not because he hates whats in front of him, but because he loves whats behind him.
Yeah it was, bit if insulation tape stopped that tho'
Just need the dry weather now
John
Clipper Cabrio 1990
Clipper Cabrio 1990
* of
John
Clipper Cabrio 1990
Clipper Cabrio 1990
