picture of working hazzard switch wired up
(In Topic #91497)
pics below of working hazard switch, two looking at the connector from the top and one looking from the bottom. not quite sure which green wire you mean as you mention the stalks, if you let me know will take a look and try and resolve for you.
1988 1.8 carb Golf Clipper
just put a volt meter on it and doesnt seem to be carrying a voltage when I switched on lights and the had the hazards on. Also its not insulated, ie unprotected spade. doesnt seem to be associated with the back lighting of the switch.
Had smoke coming from the dash yesterday which I traced to melting insulation wire by the spade connector on the blue & black wire of the hazard switch as shown in the photos above.
For safety I disconnected the blue & black wire at the spade connection. Funny thing is - everything still works! When switched on, all four indicators flash and the so does the bulb inside the hazard switch and the green indicator led on the clocks.
Only thing I'm not sure about is if the hazard switch should glow when the lights are on, like the fog light switch and the heated rear window switch? Mine doesn't.
Does anyone know what the blue & black wire actually does?
Thanks.
