Oil temp sender adaptor ??
(In Topic #76324)
ANOTHER question i hope you clever lot can help with. Ive fitted the vdo gauges to my car and have fitted the oil pressure sender ontop of the filter housing with the 2 outputs on (one for the existing mfa connection and one for the wire from the gauge)
I now want to connect the oil temp gauge wire which i know you can get a sender which screws into your sump but i would rather fit it to the oil filter housing using a T piece which i beleive can be done
Where can i get a t piece from though or am i way off track
I've always ran mine in the head take off as well ,and it works fine and was a easier to fit then int he oil housing
http://domain887009.sites.fasthosts.com/shop/index.php?act=viewProd&productId=29
Also the guages are dam cheap! The oil sender is 8 quid, and the temp sender is 5 quid.
http://domain887009.sites.fasthosts.com/shop/index.php?act=viewProd&productId=38
as i have no senders and guages that dont work, was going to get some of ebay. but i found cheaper NEW!.
Hope it helps!
So if i fit the pressure sender into the head like posted above with the 2 points on one for the mfa and one for the gauge leaving the standard sensor unconnected the oil pressure will be fine
BUT if i got one of those senders on the site they still have one connector on them meaning i cant connect the oiltemp on the mfa AND the gauge one doesnt it… :dontknow:
http://www.lma-group.com/motorsport/Products/Gauge_Fitting_Parts/gauge_fitting_parts.html
Price: ?250.00
Town: Newton Abbot
Postcode: TQ13
Bert is this a good price for a diesel it in the local Ads down here!
