oil pressure last wire.
(In Topic #141676)
hi all. never like asking for help but I'm stuck with this. background is abf in to my s1 78 gls. been through all the wiring in the car now , all working fine bar the oil pressure warning lamp. the car uses a duel circuit hand brake/ oil pressure warning lamp system. 99.9% sure the wiring is correct as the oil lamp aluminates when the oil pressure wire ( blue/black) is earthed out . question is witch one of the two pressure switches is meant to be used for s1 loom off the abf . second question is dose any one have the data to test these switches. i have tried both switches at ignition on and running the engine till fan cut in but can not get any signal off either . thinking that the switches control the earth. might b missing the obvious . but i do need this system as i have no warning and don't want to kill the engine . thanks ric
i dont know the ABF engine at all , but am assuming you cant try the original senders/switches in ?
Old unit has gone. What your saying makes sence , ill look in to the original senda should fit fingers crossed.
i'm not at all well versed on all the technical specs , but a tryer lol
