Oil Pressure Gauge Problem. Really Confused! HELP!!!!!!!
(In Topic #77713)
The pressure on the gauge is fine on start up and will do exactly what it should, but then 2 miles into the journey, the buzzer ( ) goes on, and the oil pressure VDO starts to read 1 bar or 0 bars for the rest of the journey and the buzzer never goes off!
Now, I am going to investigate the oil filter, and check the connections, but some advice as to location of these places and exactly what i should be doing/ looking out for would be so helpful!
Please dont let me drive another journey with that buzzer, I dont want it to be my cars soundtrack!
Here are some pictures that you can edit to help me, ops: .
Thankyou, Andrew
I noticed that there is alot of oil coming our onto a sender ontop of the cam-cover. Could this be the problem?
Any help would be appreciated.
Andrew
Member 125 - 2005
blue wire connected to top of oil filter
green wire connected to plate near fan housing
brown wire connected to near water hose going to head
yellow wire to sender unit on the side of the head.
is the green wire , with yellow tape in the picture connected ?
The car seems to have all brown electrical wires. Not sure if the VDO were on the car from new, or if were put on by a previous owner. Also there is a new horn so that wire may be surplus from the horn?
Thanks, Andrew
Member 125 - 2005
Not too sure where the yellow taped up sensor should connect to. Just had a look and there is no obvious place.
Could is be that the oil pressure earth is not functioning properly when getting covered in oil?
Andrew
Member 125 - 2005
Why do I still have that green wire? Any ideas? I'm trying to cure the buzzer you see.
No PM BTW.
Andrew
:dontknow:
Andrew
Andrew
Think the oil pressure switchs are rated at 0.3 and 1.8bar so VW think it should be doing atleast 1.8 bar at 2000rpm (to stop the buzzer warning)
There are so many things that it could be and I have no idea to where to start? :dontknow:
Thanks again, Andrew
