Oil light on..ish
Oil light on..ish
My oil light is just on and no more.  You can only really see it at night because its at faint.
Is this a sensor problem?  A dash/bulb problem or is it a serious problem waiting to happen.
1977 Leyland Clubman
2012 BMW 3 Series Sport.
Update
I did a full oil change and refilled the oil and the light is still faint.
You need to eliminate earth problems/back feeding.
It is imperative that you check the oil pressure using a gauge too.
if you can only see it at night does it go off when you dim the dash lights?
Racer.   No.  It stays on.
Skip….  I think you may be on to something there. I will check earths
