Oil light and Buzzer...
(In Topic #77125)
Cheers Stu.
the sensor screws in to the side of the cylinder head.
There are gazillions of posts on this sensor, and the buzzing it causes.
Have a look through and you should be able to work out how to test that it works.
If it does work - you might have a shot oil pump - which is a bit more complicated to get at, but not outrageously so.
Haynes Manual has info on checking pump.
Ali Cabrio
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
TT
I would suggest gettign the oil pressure checked with an external guage to be on the safe side.
Oil pressure is controlled by the oil bump pushing oil through the crankahft baearings so low pressure is either worn pump or worn crankshaft bearings!
Rob
Audi A4 1.9TDI - Gone
1983 1100 C
1983 1100 C
Stu
