Oil buzzer and light comes on after a short while?
(In Topic #84932)
Apart from that glimpse of the blindingly obvious, you may like to check that both oil pressure sender units are working. Sometimes a clean-up works.
There is also a possibility that the pick-up strainer is blocked [in the sump]
Try these before dismantling the dash & chasing wires.
Padraig said
You could have low oil pressure!
Thanks for the advice.I will give it a go at the weekend and see how it goes
