now moteed but with running prob any help?
(In Topic #118013)
Re: mot time today
cla55ydubs said
hi all,cars booked in at 12 today,all should be good,i dont mind a few advisories lol let you know the outcome later.
Well…?
T :?
Diesel-dubber said
Uh-oh…hopefully no news is good news!well no news is because ive bin fixin ma golf lol it failed not to bad tho rear brakes not workin cylinders had seized,left hand drive headlamps fitted so they were a fail and 2 cv boot wraps very loose,so ill crack om tomorrow buying new cylinders fit them and thats it as ive done the other jobs today ill let you all know when its passed,ian.
could be warm up regulator
CAMPAIGN-HELIOS BLUE-POSSIBLY SEEN IT ON CHRIS BARRIES(RIMMER IN RED DWARF) MASSIVE SPEED PROGRAMME?!!!
does it start ok cold but takes loads of cranking when engine is warm?
really you need a set of guages to see what residual pressure is and if its falling off too quickly
if you have a spare known to be good metering unit then try it, but just because the accumulator worked fine on your tintop, whats to say it now hasnt failed?
if the car runs fine other than this hot start issue then i cant see it being m/head, the hot start issue on my 16v was caused by the accumulator but it would eventually start after lots of cranking and foot hard down, then run on 3cyl and then steady idle, if i left it off for 5-10 mins when warm it started fine, but any longer it was a pig
if the fuel vapourizes in the lines then surely it would leave a vacuum in the lines and by cracking the banjo your releasing the vacuum and allowing fuel to flow?
was the accumulator an original item on your tintop? how old is it?
do a search for hot start issue
Give it a go but it could be a number of things!
MK1 1990 16v GOLF GTI CABBIE
ive got no fuel at the injectors until i crack the banjo then hey presto,GazzaBangor said
I have a similar problem, Starts first time when cold, but when engine is warm it takes a good few turns to start. I have been told this is down to the injectors dribbling and causing the engine to flood???
crack the banjo i think is my new saying
fault finding= test first and replace where faulty never assume that something working 1 minute is working perfectly the next!
10yo acumulator?
youve ruled out leaking injectors
at the minute your making guesses, dont, test system
bottom line is, is the system holding the correct pressures? fuel pressure is critical to mechanical fuel injection
if you find no fuel comes out while you're cranking it with the wur pipe off for a bit, then thats almost deffo down to an airlock in the system or some kind of fuel delivery problem.
as already saiud, your best bet is to get some k-jet fuel pressure gauges, this will tell you exactly what the issue is. without this you can spend a lot of time and money guessing at which item is at fault!
