No main beam, no fan, low tickover and a whirring noise
(In Topic #138359)
Last night my Golf cut out from a cold start which is perfectly normal seeing as I still haven't got round to reattaching the choke lol. However when I started it again I had dim headlights, no fan and quite a loud 'whirring' noise coming from the engine bay. Would I be right in thinking that this could be an alternator problem? I've checked the belt and that's fine. I am going to get my multimeter and check the battery terminals in a bit. It's a Clipper.
Are there any other things I should check? To my ears the noise seems to come from the starter motor more so than the Alternator but it is quite hard to tell.
Thanks in advance
Hope this helps???
I have had a proper look today and it is something to do with the ignition switch or barrel, when you turn the key all the way it does not kind of 'spring' back any more. So as you say it's stuck in the ignition position and the car gives electricity to only certain things.
You can turn the key back to the normal position it stays in when your driving (sorry I don't know the correct names for the these positions lol) so it is useable but i'm going to have to fix it as eventually it's just going to pack in all together isn't it.
I guess I need to replace the barrel?
Dan
Cheers again.
