No live to the rad fan circuit and wash/wipe not working
(In Topic #122158)
My rad fan is not kicking in when the engine gets hot.
Fan works when directly connected to power on both speeds.
Bridging the temp switch does nothing. (and a new temp switch has been fitted)
I have checked for 12v at the rad fan/temp switch circuit (ie where it meets the main loom) and its dead.
All fuses in the 'box have been checked with a multimeter.
Are there any inline fuses/relays that operate this circuit? If so which ones?
Also the wash/wipe is no longer working could the two be connected?
Both wiper speeds work but no wash. This switch was new a couple of months ago as the last one failed the MOT.
I didn't have either of these problems until I hit a rather big pothole a few weeks ago (ruining the passenger side suspension) could the jolt (or the garage that repaired it) have pulled a multi plug apart around that area causing these failures?)
hopefully that will solve it. I'll post back when I've returned home and had a chance to look properly
