no instrment except speedo
(In Topic #73546)
have a problem, which i think i know the answer to but wouldn love to know if any of you guys have had the same prob.
at first the dash was ok and worked 80% of the time. then over time it cut out, and now none of the instrument or warning lights work. all that is except for the speedo, and since thats the only mechanicaly driven device i'm thinking it either the multiplug or the printed curcuit board. still have illuminating lights.
i been told its probly the pcb that gone which is common on old golfs. any ideas where to get one or is it worth getting a new dash fitted?. if it was the multi plug, would all the instruments and lights go at once?
thanx for any advice.
Other than that, you could check if you are getting voltage at the 14-pin multiplug.
It's a fair chance tho that it's knackered and you'll have to get a replacement as they often break at this age. Is it clock set with MFA? Either way don't spend silly money on clocks on ebay as you can buy cheaper elsewhere.
Oh, and welcome to the club! What Golf model have you got - any pics to post?
thanx for the welcome. hadnt thought about the earth points, but will check those. i dodnt have a MFA just the standerd dials. with the rev counter instead of the clock.
i have had a far bit of trouble with the electrics on the car, which i can pretty much guess is the old wiring, and have been thinking of replacing it for a while altho i cant afford to really spend mony on the car for at least another year.
cheers for the advice.
Anyway, goodluck and keep us posted - if continued problems let us know and we shall try and help!
thanx for the tips tho.
Basically they go grey and furry and won't conduct anymore.
I have fixed a lot of electrical problems by unplugging, spraying with electrical contact cleaner and reconnecting.
Get yourself some contact cleaner it's a good start.
F*rd Lighting responds well to this method!
Peter.
1980 1600 GTI, daily driver.
dash probs
update on the dash prop, finally got it sorted. replaced the voltage stabaliser, which as far as i can tell was faulty. gave it a test but still nothing! ahhhh!
after pulling my hair out a bit, i decided the only thing left to do was test every circuit individually. finally found that it was a broken track on the pcb. the supply to the stabaliser. (black wire on the multiplug, either 1 or 14.) had to soler a bypass wire to it.
gave it another test and bobs your uncle fully working dash!!! yay! only prob now is i seem to have lost the illumination light for the spedo. there was black wire which i think was the power solderd to one of the lights, and another which was just fixed to the instruments. anyone know if its an eart wire or if there should only be one?
thanx guys.
andy
