no indicators
no indicators
had a proplem on my 83 gti with my oil light buzzer,so i took the clocks out & found a loose connector sorted that out and put it back together but my indicator flasher bulb stayed on (although not very bright) so i checked my fuses one had blown so i changed that (it blew again) basically when i put the indicator on the bulb lights up bright but the lights outside dont,has my flasher relay gone ? please help thankyou. :banghead:
sounds like a dodgy relay does the hazzard switch work?
hazzards work fine
does the hazzard swithc acctually flash with the ignition on? i had the same problem the other day and i think it wasone of the pins on the hazzard swithc had come loose. also earth the clocks to the bulkhead behind the dash, makes the world of difference!
  Mk1 Jetta (Jessie) build thread here
 View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
 T25 westfalia camper, 2.2 Subaru powered
 vw touran   1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck…….  www.jsgarageaberystwyth.co.uk
yep, hazzard switch does flash.
my monies on a faulty flasher relay .
try adding an extra earth to the brown wire on the plug on the back of the clocks, works everytime!! its a bad earth on the clocks and it always earth's itself throught the indicator light if the original one is faulty.
