no indicators
(In Topic #90117)
no indicators
ok, to start i dont have a clue when it comes to electrics, anyway
i have no indicators, but the hazard lights work.
i have checked the fuses but none are blown
anyone any idea what it could be or where i start to find out
PROJECT CABBY
Is the green light on the dash faintly lit all the time? If so, then tt's most likely to be the hazard light switch itself.
Prize the switch apart carefully, and you should find 2 springs that fit underneath the contacts in the sliding mechanism. If they're not there then it usually prevents the indicators from working.
While you've got it apart, clean up the contacts inside, and make sure the contacts on the back of the switch are clean and firmly connected.
HTH
Rich
HTH
Rich
light is on, ill try that cheers
PROJECT CABBY
didnt work, springs are there(3 of them).
any other ideas
any other ideas
PROJECT CABBY
This has happened to me before and many others and it always turnes out to be the fuse. Yes I know you've checked it before but so did I. Eventually I simply replaced it and bingo, it worked.
Start by trying the indicators without the fuse at all and see what happens. If it's identical then Bob's your Uncle.
Tian :wink:
Tian :wink:
We all know these electrical problems are maddening…
I had the same problem. After many days of wanting to take a lump hammer to the dashboard I bought a brand new hazard switch and as if by magic, all worked. I believe that the indicators are wired through the hazard switch, so if all is not well at the switch, indicators wont work. Mine had the dim indicator light staying on at the dash when signalling. If you dont know what you are looking for inside the hazard switch, it could be faulty. Try a brand new one if all else fails.
Gary.
Gary.
83 Mars red GTI
01 V6 4Motion (daily driver)
09 Golf GTI MK6, candy white, superchipped!
hi.. i have got exactly the same problem with my 91 mk1 cab. little green light is on (dimmly) all the time. but then just stays on when you turn the left or right indicator on.
hazzards all work all bar front passangerside one there is no power getting to the front passanger one for some reason but is to the side repeater???????????
