no indicators part 2
for those of you who saw my last post i have a glowing indicator bulb on my dash, that dos'nt flash & no indicators,(83 gti 1800cc)bought a new relay today but that did'nt help, what the hell is going on !!! iv'e no idea  :banghead:
Do the 4 way flashers work ? If you pull the wiring plug from the indicator stalk does the light go out ?
Does every thing else on the car / clocks work ?
hav'nt try'ed pulling the wire of the stalk yet but the 4 way flasher does work as does everything else.
Sorry but I haven't seen your post 'part 1' but when I had exactly the same issue it was simply the fuse. Sounds stupid I know but I checked the fuse and it looked fine!
Only after I changed it regardless of how fine it looked did I have any success.
Good luck with it.
Tian :?
Pull the wire off light goes out could be stalks faulty , its a switch at the end of the day and the switch may be faulty .
Can't think of any other reason why they don't work , relay would have been a safe bet , but as you say you have changed it and 4 way work so …….. you have of course checked fuze 19 and have a handbrake light ? You did say every thing else was working .
thanks chaps will have a butch over the weekend .
See the post recently with the photographs of the rear of a hazard switch, I understand that the indicator wiring goes via the hazard awitch, so it would still be possible for the hazards to work and the indicator side to be wired wrong. I had the indicator light glowing problem, a new correctly wired hazard switch fixed mine.
83 Mars red GTI
01 V6 4Motion (daily driver)
09 Golf GTI MK6, candy white, superchipped!
Didn't see part 1 either but try this first mate, has worked for loads of people. Think it ends up being a dodgy hazzard switch, but this works fine in the meantime:
http://www.vwgolfmk1.o…wtopic&t=32631&highlight=
1982 1.8 GTI Mars Red
gingermatti you the maan!!! seems it is a dodgy hazard switch nice one,once again i have indicators. :D
One for the archive section !
Thanks to all for what is a simple solution to a difficult problem .
