no fuel,spark or starter motor!
(In Topic #77654)
as for your 1st problem if your pump has gone down you may loose the spark, it may be the fuel injection relay, they are not to expensive and easy to swap, it should be the relay in the second space from the left, on the top row, an original relay should have number 2 printed on the top. but with the mileage getting higher on the mk1's the ignition switch as mentioned above is also worth checking.
Regards Volkswarren
by the way the car will be up for sale when the work is completed due to me being too young to qualify for classic car insurance
the car is a 1983 golf gti campaign, EW chassis number,its alpine white colour,it was stood for 5 years before i got the car,it had a replacement gearbox and head the cylinder head rebuilt before it was taken off the road.the car has koni adjustable suspension and drilled front discs and fast road pads.i've had all the welding done on the car in the last month,this included the roof as it had filler in the drainage channels,it has all been plated up with steel and doesn't leak.the car has a jetex exhaust system fitted and a k & n panel filter,it has 15" alessio alloys which have been painted gloss back to match the side strips on the car.its had a pair of new front tyres,its not even done a mile on these,oh and the car has a high lift piper cam fitted,90% of the work is documented for,with over ?10,000 spent on the car in the few years leading up to it being taken off the road.the interior is in great condition for the mileage of the car,with no stains,rips or tears,and the bolsters on the front seats aren't worn at all…which is great considering the car has done 184,000. the car will be sold with a full m.o.t. the car has a 5 slot aftermarket single lamp grille,but i still have the original campaign grille.the car had had new rubber fuel lines made and fitted and new brake pipes made and fitted.i think thats about it,there is alot to this car and i really don't want to part with it
