No dipped beam...
(In Topic #81008)
No dipped beam...
Maybe your problem, or maybe not.
Have you checked for voltage anwhere with a multimeter to see how far the power gets?
Copied from an old post , wiring colours may help ………
This has its own fuse check again in the fuse box . And its own relay but i think it runs all the high beams but is worth checking anyway . If not you want to be looking -and you have swopped the bulbs to the other side?? to check - in the fuse box . From memory lights use white and yellow cable one side [high and low beam ] and yellow/black with white/black cable the other . Yellow is high beam and white low . You have to check if 12 volts is there if not its off to the fuse box you go ….to find out why
Only downside… 8O
Do vw still sell these? Don't fancy having a fire in there…
Thanks for your help all…
