New loomage
(In Topic #118816)
New loomage
Thanking you
Richy
Ta
Regards Volkswarren
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=38676
the ignition controller loom on a 16v is as simple as it gets, plug n play into an existing engine loom as it has nothing to the fusebox except the fuel pump trigger wire. if you use a mk1 k-jet fuel pump relay without a rev limiter in it you don't even need to hook that wire up.
if you want to replace the whole car loom with a later one, its pretty straight forward. main difficulty is getting it laid out as neatly as original, takes a bit of thought
advantage of the later blade fusebox is there are a lot less random wire connectors behind the fusebox for stuff, and less extra relays & fuse holders clipped above the fusebox. Most of the wiring is integrated into the fusebox instead. Plus with the haynes wiring diagrams for the MK1 being very good, its easy to figure stuff out.
The MK2 haynes diagrams are pathetic in comparison, they're not in order and at least 50% of them are missing!
the ign loom i mention is literally just that, the bit that does the ignition. this doesnt cover all the cold start bits, sensors etc etc, that you'll need a proper engine loom for. if you get a MK1/cab/rocco k-jet injection loom, most of what you need is there.
only extra you'll want is the ISV control setup, though you can do without. some have used a MK1 type AAV instead, or just done without entirely. you have to up the idle a bit and it'll run a bit poor when cold tho.
I've just done a MK1 16v loom, not much work there just a few tweaks on the loom lengths. most of it is too long, just 3 wires for the ISV setup that need to be lengthened.
Ive managed to get hold of a mk1 blade fuse box so ill have it within a few days. In order to change them over, its just a swap?
u cannot just fit the later fuse box without major work to the loom, a late cabrio loom is a good bet to go for.
Regards Volkswarren
Regards Volkswarren
The car doesn't have the ISV connected at the moment, or the cold start injector and its annoying waiting for it to stop running badly before i can drive it even slowly. Ill see if i can get hold of a complete kjet engine loom on the weekend if the local vw breakers come good. The majority of the wiring inside the car, lights, stereo etc is fine, so itd be a case of using a bit of both looms, im taking it thatd be ok?
Sorry again, just dont want to mess it up lol
Cheers to both
Ta
Mk1 Cab:
Mk6 GT TDi
Mk6 GT TDi
as you say, as with any engine conversion loom its a case of using bits of both. for the MK1 I used everything from the MK1 loom that isn't for the engine management i.e. oil/temp sensors, wiper motor etc and added in everything from the mk2 loom that is for the engine management
You'll also find that the 2 wires from the cold start system run to spade connectors, so its simplicity itself to shorten the mk2 wires to suit and crimp spades on, then plug in as per MK1.
The ISV controller loom is completly seperate from the fusebox except it requires 2 ignition live feeds, one for the isv control unit itself and another for the throttle switch. so that's dead easy.
Last of all the ignition controller, that's totally self contained except it has a 2 pin plug with a yellow/red and yellow/black wire. yellow red goes to fusebox (fuel pump trigger) yellow/black goes to idle switch loom. easy!
With the fuel pump wire, if you get a pre-90 16v MK2 loom this is ideal, just chop the fusebox plug apart till you can remove the red/yel wire, unless you can find a fusebox pin removal tool that fits. If its a post 90 you need to find a donor plug you can chop up and splice this wire to.
Or you can just skip it and fit a blade fusebox type fuel pump relay for a k-jet 8v without a rev limiter built in. These can be had from GSF:
93592 k-jet relay without limiter £ 23.20
Mk1 Cab:
Mk6 GT TDi
Mk6 GT TDi
Right i think ive got that bit in my fried brain many thanks for that, just need to find a loom now, if im not able to, you mentioned making my own would be relatively simple, itd be a case of getting the correct wires/connectors and going from there, with a diagram? Might get the relay you mention, sounds easier and i need all the help i can get i think. With the mk2 16v ECU that the car runs at the moment.
Cheerys
combine the 2 to make a MK1 16v engine loom
You can really just plug a MK2 loom in and expect it to work, because on the MK2 the fusebox is on the driver side of the car, whereas on a MK1 its always on the left side of the car regardless. This means the lengths are all wrong, so tweakage is required. To make this easier you keep as much of the MK1 loom as you can, to reduce the amount of chopping & splicing required.
If you could find a LHD KR engine loom that would probably be pretty much perfect, however most euro spec MK2s tend to have the PL code engine rather than KR, which means its slightly different again.
richy: pm me your email address and I'll send it to you
Mk1 Cab:
Mk6 GT TDi
Mk6 GT TDi
