new horn; to relay or not to relay
(In Topic #78385)
It seemed to make sense that if I wired in the little compressor to the same two wires that split into the existing horns then it would get power the same way they did. This seemed to work in as much as the compressor made noise, but no noise from the horns, so to test the compressor was working properly I earthed the -ve on the compressor and touched the +ve to the battery and the horn rang out loud and clear.
So, would it seem likely that I can't just wire the horn into the existing electrics and that I have to use the relay they supplied? Has anyone else fitted a new horn to their motor and how did it go?
thanks as always, jc
Make sure the compressor is mounted upright with wires at the bottom and if i remember you need to put oil in a little hole at the side of the commpressor and good luck. :wink:
I ended up wiring it up with the relay and now its loud and clear all the time. This might be perculiar to me, but there's my experience incase it helps anyone in the future.
