Need Help Pleeeeease ABF Crank sensor
(In Topic #117115)
Does anyone know what goes where from the crank sensor??????
What wire goes where. There are three pins fron the sensor.
Please help. Im desperate to drive!!!!!!!!
Thanks.
Heres the testing procedure for the sensor:
and this is the wiring for the sensor
You need to be looking at the component with red hatching marked B54 / B75
The most lower line is the BAttery negative (component 31 furthest left) and component A35 large across the middle is the ecu
ALSO: pin 3 attaches to the following:
Component A166 / B132 - Distributor
Component B147 - Throttle position sensor
Component B24 - Engine coolant temp sensor
Component B25 - Intake air temp sensor
Component S57 - Closed throttle position switch
hope this helps
<a> <img></a>
awesome mate
if you can find a sensor on your ecu that you know the pin locations of i can cross reference this with autodata for you
<a> <img></a>
Thanks but still no go. Have wrote everything down. Help????
Here is my ecu and layout:
Bosch 68 pin ecu no 037 906 024 AB
1 brown
2 grey with blue stripe
3,4,5 blank
6 yellow with blue stripe
7 red
8 green with red stripe
9 black with red stripe
10 black
11,12,13 blank
14 blue with brown stripe
15,16,17,18,19 blank
20 yellow
21 grey with yellow stripe
22 green with white stripe
23 black with yellow stripe
24 grey
25 grey with green stripe
26 grey with red stripe
27 white
28,29,30 blank
31 green with yellow stripe
32 white
33 brown with blue stripe
34 yellow
35 blue with white stripe
36 white with yellow stripe
37 blank
38 black with white stripe
39 green with grey stripe
40 red with blue stripe
41 red with white stripe
42 white
43 grey with white stripe
44 blue with green stripe
45 red with black stripe
46,47,48,49,50 blank
51 purple with white stripe
52,53,54 blank
55 black
56 blue
57 grey
58-66 blank
67 green with black stripe
68 red with yellow stripe
I have the following wired up:
Pin1 0v ground
Pin7 ignition switch
Pins10,32,34 knocksensor #1
Pin33 0v to loom
Pin38 ignition switch 12v with 10amp fuse in-line
Pin44,45 to dizzy
Pin55,56,57 knocksensor #2
Pin67,68 crank sensor
On the coil connector 1 is 38
2 is 8
3 is earth
On the dizzy 1 is earth
2 is 44
3 is 45
If you could help me out it would be a massive help. Still dont have a spark. Was thinking it might be immobilised(the ecu). Or the coil is feked or the dizzy. So upsetting. 3 months without my car boohoo
<a> <img></a>
