my battery light isnt coming on and alt not charging
(In Topic #140894)
need to rack your brains. ive got a 1983 driver and the battery isnt charging and the bulb in the dash
wont light up.
the cause of all this was my brother and i getting some wires mixed up when fitting a cd player the
power was coming off the cigarette lighter (someone has hacked into it before) so we got the wires the
wrong way round blowing a few fuses in the process. now after that the battery light in the dash didnt light up
and the battery wasnt charging.
so ive been online done all my research had a new alternator ive checked the blue D+ wire. now on friday
i had the dash out and discovered the bulb had blown, so i replaced it with a new one but still no luck in the
light coming on and i dont think the battery is charging still.
has anybody any idea what to do? this is my daily so needs to be sorted asap
cheers Mitch
That shows the alternator is charging the battery.
Does the battery hold a charge? You will find out that you wont be able to start the car.
There is a voltage regulator on the back of some clocks that can can go.
Or the PCB foil on the back can be damaged.
You need to trace back what you did and check all the wires and fuses to see if you can find the damage.
get some pics up if you can of any damaged areas.
