MPG meter, reversing light switch.
(In Topic #146185)
I found a multiplug disconnected from my gearbox, i reconnected it and magically my MPG meter started to work, even the MPG average seemed reasonable. After a few miles i was confronted with 99.9MPG on menu 1 and 99.9MPG on menu 2 and a MPG guage which was reading in every gear, i was under the impression it should only work in 5th. My reversing lights are stuck on too.
So, waffle aside i assume the switch is bust and it thinks it's in 5th all the time. New switch is ordered so should cure it, am i being unreasonable to think that one day i could have a fully working and reasonably accurate MPG meter? and does anyone have an idea as to why i was getting a reasonable MPG figure but then it went up to 99.9 for the remainder of the journey?
Thanks,
Rob.
Is your cable operated speedo still working? - The MPG readings on the MFA are calculated engine vacuum AFAIK.
R32GUY
1992 Rivage in Classic Blue Pearl "B16YUG" 2.0 TFSI, 6 Speed FWD with Quaife LSD, running on Air with sorted geometry and Eibach ARB's, G60 brake setup front and rear, 4x100 17" BBS LM's, Power Steering, Opening Quarter-lights, Mk2 electric recaros and the whole car trimmed by MJ Interiors in tan and Alcantara with a brown roof.
Yes, the speedo and tacho are both working. Its not the speedo sensor which i reconnected, as far as i'm aware, the mpg needle will only register when the gearbox is in 5th and this is controlled via a switch which is integral, or at least piggybacks onto the reversing light switch. The multiplug which connects to these switches was disconnected by a previous owner, obviously as an attempt to stop the reversing light operating all the time, instead of replacing the duff switch. The vacuum pipe has been connected all the time i've owned the car, althougb it needs this for the MPG gauge to work, it also needs an input from the gearbox. At least this is how i understand it!
Cheers,
Rob.
the gauge up top i believe only works in 5th but the one in the digital display will work all the time (i assume because the digital computer gets a speed signal from the cluster, but analogue gauge does not)
the shift light is controlled by the vacuum switch inline with the vac line to the dizzy, and both mpg gauges use a vac signal from the engine so check the hose is intact and connected round the back. if that all checks out then i would say the vac sensor on the clocks is broken or the pcb is at fault somewhere
We'll get there eventually!
Rob.
Cheers,
Rob.
i have a small clear nylon tube which goes from the instrument cluster to the inlet manifold, this operates the mpg needle, i had no idea there was one going to the dizzy too, i hope this is the baby!
Rob.
Interesting… Got any pictures?
R32GUY
