MPG guage not working.Any ideas very welcome!
(In Topic #85677)
Dombash
TT
re mpg guage
The problem (more than likely) will be in the engine bay -
The vacuum for the gauge is derived from the inlet manifold - this vacuum hose connects to the distributor - see below:
The gauge-needle is designed to only work in fifth gear (as detailed in posts above).
Inside the gauge there is a electro-magnetic switch - no power - switch open - with power the magnets pull a contact plate forward to close the switch thus opening a circuit to a second electo-magnet - same as in a voltage regulator.
Power to the switch comes from the distributor. This circuit is in turn opened /closed by a switch on the top of the gearbox - detailed below:
You need to trace the (brown?? - thinks its brown) brown wire from the top of the gearbox to a connection block that joins the circuit frm the gearbox to the circuit from the distributor - shown below:
Contrary to popular belief the gauge itself is not driven by vacuum - it is driven by variations in the electrical output coming from the distributor. These variatoons are transferred to an electro-magnet within the gauge. As the power output to the magnet increases / decreases, the more / less poweful the magnetic force, causing a metal plate to rise / fall. This metal plate is linked to a lever that causes a cog to rotate thus causing the needle to swing to and fro. Shift out of 5th gear - the electreo-magnetic switch opens, breaking the circuit - the metal plate jumps to its (natural) un-influenced position and the needle "snaps" out of sight.
Quite cool really. The gauge is nicely made & involves a great deal of engineering - I have a spare if you need it.
Hope this helps,
MP
Re mpg guage
MP
Michael I think you just answered my question i just posted on the end of the MFA poll your running. Only just noticed i have no reversing lights, as well as the consumption gauge!
Will be checking the switch on the gearbox anyone know how much these are and if they are main dealer only?
<a href="Image hosting, free photo sharing & video sharing at Photobucket"><img src="http://i159.photobucket.com/albums/t147/dkingvr6/sig-2.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
MK1 Campaign and Mk4 GTI 150 Diesel
So i thought this aint going to work, but it does fine.
Now the problem i had was that the needle and gear change light just stopped working, it was at this point i started to investigate everything and found that my reversing lights were not working.
Although the needle used to come on in every gear and whilst on tick over????
I noticed that there was a broken brown wire on a 2 point multi-plug that joins the brown from the gear box switch to the brown of the vacuum switch on the distributer, joined this up to an earth (as in the wiring dia).
The gauge needle came back on in every gear, but still no reverse lights.
So installed the new switch, and hey presto gauge only works in 5th and got reversing lights again so switch was naff.
BUUUUTTTT, i stil do not have a gear change light, anyone know how this works and where it gets it feed from??
I'm asuming that it gets its signal from the vacum switch on the distributer as per the gauge needle, then this signal goes through the control unit for shift and consumption indicator (relay part number 171 919 091 C from ETKA)?????
If this is correct and my needle is working i have now two choices for an error,
- the LED is blown (thought they lasted for everish???)
- the control unit/relay is knackerd
Whats your thoughts??
