mk2 wiper motor upgrade
(In Topic #75169)
Dave
my wipers have 3 speeds, slow, juddery and very judery.
1983 mk1 gti 2.0l 2e powered
newman cam
ported, polished, big valve 1.8 head
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
Before doing that make sure your wiper mech is clean and the spindles are free as they get stiff.
Rich
Life Member
Easy to do, you just need to make up about 5 short jumper cables with the appropriate spade connectors on each end.
The Mk1 Plug and the Mk2 Motor each have the terminals numbered. Just match up the numbered pins with the leads you make up - job done!
My Build Thread
dubboy said
I always wondered if a late Cab would have a more powerful motor but Mk1 connector. Anyone know?
I have a 1990 cab give me a pic of the connector and I'll check it out with mine, motor works well, so unsure if it's different or not
Audi A4 1.9TDI - Gone
AL_Mk1 said
I fitted a Mk2 motor to mine though I have removed the pics from my webspace!
Thinking about doing this ASAP. Did it make a big improvement? Was it that easy to do? Just unbolt one and bolt the other on?
Cheers.
Shonky
'82 Mk1 GTI 1870 160bhp
'83 Mk1 GTI 1800 (Now deceased)
'80 Mk1 GTI 1600 (Now deceased)
'81 Mk1 Golf 'C' 1093 (Long-Awaiting racecar transformation)
Audi A8 Sport (Gone but not forgotten)
Toyota MR2 MK1
Toyota MR2 MK1
Cheers.
Yep!
The motor sits at a different angle to the Mk1 version, which means that you can't put the brace that goes from the motor to the bulkhead back on. You could quite easily make one up to fit though, but it works fine without it.
My Build Thread
I'll post this in the 'wanted' section too.
Cheers!
Shonky
Toyota MR2 MK1
Toyota MR2 MK1
Thanks anyway!
Shonky
Toyota MR2 MK1
Toyota MR2 MK1
