MK1 golf indicator and hazard light fault?
(In Topic #109952)
drive a tuned mk1 golf gti, and a 20vt mk2
I've moved your post to the technical section of the forum (Electrics) so hopefully you'll get some helpful replies soon (not everyone visits the Newbies section regularly).
What things, if any, have you tried so far to remedy the problem? Even if the hazard switch is dead, the indicators should still work. I'm thinking relay. Hopefully someone else can add…
But have also seen water in the fuze box and wet relays causing the same thing for location see The Mk1 Golf Owners Club
hth
will deffo be a switch or relay..
