mk1 G60 wiring loom
(In Topic #125460)
mk1 G60 wiring loom
im collecting parts to do a G60 conversion on my mk1, will a G60 loom plug straight into a mk1 fusebox or does it have different connectors? thanks
It will have different connectors, G60 loom will have connectors for a CE2 fusebox, depending on the year of your mk1 it will have CE1 or earlier type fusebox.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
its an 83 campaign, nice 1 i'll take it to TSR to get converted, cheers
Hi there what sort of workis it to drop a g60 engine in? Do you have to replace all the wiring loom? what other problems have you encountered? I take it you have to change the engine mounts and radiators etc?
Neil
Neil
Neil
Sorry bad english!
I've just done a engine conversion with a ADY 2.0 engine with a G60 head and G60 Wiring.
Use engine mounts of the old engine.
I did use the original loom for the fusebox and used the g60 loom for the ecu.
Did conversion in one day, at the end of the day it runned but the day later it did'nt start anymore. still having this problem because i don't have time to fix it.
