mk1 engine troubles
(In Topic #84394)
mk1 engine troubles
I'm in need of some advice…I seem to be having battery problems. This is the second battery I've changed this year and I seem to be having trouble with it again. I've cleaned and checked all the connections, but still having trouble. Could it be cause my car is stored in my garage most of the time?
Help… :dontknow:
My car is only used every couple of weeks now. I don't have a garage so I just disconnect the battery. Starts first time everytime afterwards.
Danny
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
If you've had three dead batteries in a year (as in dead, defunct, unusable, expired, rest in peace etc) you might have problems elsewhere like;
- a duff alternator that isn't charging at all
- a duff regulator/rectifier so that the alternator is charging at too high a voltage, thus cooking and killing the battery
- an electrical short that drais the battery when you don't use it
or a combination of these
First - check the battery - once charged, does it;
- Start the car OK
- light the lights OK (check for a few seconds to make sure)
If it lights the lights, but will not start the car - then you may need to sort out the starter motor/solenoid (a job I'm going to be doing v soon)
Then
Start up and check the battery voltage at idle, and when you rev the car up a bit (up to 3000 revs is plenty). Does it;
- Stay at about 13 - 13.5 volts (= OK)
- Stay at 12, then go down/not rise ( = maybe alternator not working, check the wiring)
- Rise from 13 to 15 ish or more (= regulator up the swannee).
The reason I know about this is because I own a Honda VFR400R NC30 motorcycle - their alternators/regulator-rectifiers on these are race spec - as in designed to be unbolted and thrown in the bin before going racing…..
Al Cabrio
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
Alicabrio - you have PM bro'
MP
