mk1 16v earth problem?
(In Topic #124234)
I have just recently converted my 89 mk1 cabriolet with a 16v kjet.. im having an electrical issue and im ageing very quickly trying to fix it
basically when i turn the ignition on sometimes the fuel pump primes, sometimes it doesnt! sometimes the oil light flashes as expected but sometimes it dont! and i have also noticed the rev counter blip slightly when turning the ignition on.
Finally.. when turning the engine over the fuel pump clicks like f*ck but again not all the time!
Occasionally I can turn the ignition on and start the car with none of the above problems.
Can anyone please help..pleeeeease
Thank you
dan
MK1 83 Jetta… 2ltr 16v ACE
MK1 88 caddy pickup 20VT soon
MK2 Golf 90spec 2ltr ABF coming soon
T5 TDI
T5 TDI
cleaned and checked the earth straps to and from the coil also been under the dash and cleaned all the earth areas
even on the battery but im getting intermitant dash problems
any idea,s
Checked main earths…. battery, gearbox, chassis leg and head. found the battery had been leaking at the earth terminal and cause corrosion. Replaced baterry, still having problems.
Checked black ignition wire and found a dry solder joint. Repaired this and it seems to have solved the light issues on the dash but im still having problems with the fuel pump not priming every time.
Jasonc, what dash problems are you getting?
no dash lights or rev counter ,fuel gauge
its only when i turn the key on and off fast that sometimes thay all work
ive took the dash out and found a green and white wire in the loom that go,s to the clocks burnt all the way down but cant seem to find where it go,s as ive checked all the connectors and nothing visable
maybe an old issue with the car ?
looking on the fuse thread above its the fog light or wiper wire
id try repairing the burnt out wire then trace and test all wires leading to the fuse box.
feeling a bit gutted with it at the mo
fix it or buy another 1 lol
just replaced the whole lot underneath from wishbones to pipes even replaced all the shocks and springs and with nylon bush,s
time out i think for a while
as in the part i need it from the fuse box i assume to the dash,clocks ?
or is it 1 complete loom
also got another car to look at
