Mk 1 Golf Cabrio - power roof problem
(In Topic #99014)
Thanks in advance.
Tim
you may need to get some wd40 and spray the joints on the frame then get a willing helper to press the buttom while you help it down :wink:
check the fluid level in the hydraulic ram is correct and that the switch is working correctly, if you have electric windows? just swap one of the window switches over onto the hood one! they are the same plug fit and it will prove/negate its the switch at fault
