Mfa upshift and econometer wiring
(In Topic #163012)
I've been tidying up the wiring on my 1.8mk1 gti , just about got everything working as it should now apart from the mfa upshift light ( i'm sure this worked when i fist got the car 20 years ago ) !!and econometer ,( i've never seen this work) i have the wiring and in line switch on the vacum line sorted but it still does not work , also i can'nt find the wiring for the 5 th gear signal on the gearbox , the gearbox has the multi pin switch on top but just has 2 wires for the reverse lights connected direct via spade crimps,( i did this when i swapped the gearbox 15 years ago ) absolutely no sign of any more wires for the 5 th gear signal
Q1, did all 1.8 mk1's need the 5 th gear signal for the econometer ?
Q2, can i wire this myself all the way back to the clocks ? If so what pin on what plug do i need to connect to?
Please help me !
1. yes
2. if you bridge the two wires that would have connected to the 5th gear switch the enometer should work all the time, it will not however be very accurate in any gear but 5th.
I cant remember the gearbox codes off the top of my head but the box you swapped out would have been slightly different from the box you refitted, hence nowhere to plug your wires in.
Do it once and do it right! ok, we've identified the problem, lets not make it worse by guessing……… Identifying the sympton is not the same as understanding the cause
The part of the loom that has the reverse light wires in only has two wires : a black and a blue / black if my memory is correct
I've looked everywhere which makes me wonder did it ever have the fifth gear signal from the box ?
Hi guys! I'm having a hard time locating those wires on my '88 gti cabby. Does anyone have a picture which would help me locate the wire? The reason why I'm asking you this is because English is not my native language, therefore its hard to understand which parts you guys are talking about.rubjonny said
the mfa upshift wires will be part of the engine loom, the reverse wires come from the lighting loom. they're green/white and red/white, have a good look startign from the main grommet in the bulkhead where the engine loom comes thru. if you have the vacuum switch on the dizzy vac pipe then it did originally have the upshift wiring in it. if not then perhaps not!
Many thanks!
Matas
