mfa switch
(In Topic #76621)
mfa switch
anybody got a wiring diagram for that part?????
I extended the length of the wire as its really too short and becomes pulled too tight before the other wires to the connector. I did a neat job soldering the wire together, used shrink wrap and soldered the wire to the pin in the connector. I took the pin out of the connector to do this.
Cheers,
Ross
….To the rocker cover!!!!
This earth also serves:
? Instrument panel lighting
? Clock/mfa light
? Voltage stabiliser in the dash which then serves:
o Gear change light on tin tops
o Engine oil pressure control unit
o Engine oil pressure light
o Alternator warning light
o Coolant temp light
o And more…..
This explains why if the brown and white wire comes off the rocker cover there are so many problems!!!
