mfa says 75+ mpg ? help
(In Topic #78166)
My GTI, in the seven years I have owned it has always read a high mpg on the digital display.
Is there a diode or something somewhere I can change .
Also since I fitted an oil pressure gauge, and solderd into the wire sending the signal to the mfa , the VDO gauge works fine but the reading went from that mfa position.
Any help would be great, thanks
Ali
Sorry I just noticed I ment oil temperature gauge. mon 10.4.06 2015hrs
As for the oil pressure gauge, I didn't think there was a sensor for this in the mk1 as standard, the read out on the mfa is oil temperature, not pressure as far as I know? I would guess the mfa doesn't like the fact that something else is stealing it's signal, it's probably changed all sorts of characteristics in the wiring, like resistances and voltages, upsetting the electronics in the mfa. I would probably put in an additional sensor for the vdo gauge, and leave the existing wiring as it is, creates less problems.
Mike.
1983 White cabriolet GTi
The original oil presure senders are simple on/off switchs to run the low presure light and buzzer. As mentioned the MFA is temp not pressure. You need a VDO oil pressure sender that matches your guage.
You might want to check and clean the electrical contacts on the distributor and alternator and the cylinder head earthing strap*. Also check the vacuum hose that comes from the intake manifold for leaks/holes.
If that doesn't work, console yourseld with the thought that if the MFA were analogue, it would probably be the size of your gearbox, rather than fitting behind your dashboard….
Ali Cabrio
*MFA fault-causing prime suspect number 1
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
Big
MFA on golfs was only a gimmic in my opinion, and doesn't really serve a useful purpose. The temperature readouts are just as bad, if you switch to the oil temperature, then turn on your fan blower and head lights, the reading jumps about 8 degrees straight away becasue of the changes in voltage in the car, so that's not very accurate either.
Mike.
Ali
do ya feel guilty now?
Woohoo, no leaks... splash... Damn!...
