MFA or Computer help needed.
(In Topic #75542)
MK1 Mars Red Campaign
Member 125 - 2005
mk1jim said
hello, have you checked the connecter plugs ( near the gearbox) are still connected, also check the earth straps are still inplace especially the one from the back of the rocker cover. hope this helps. fingers crossed knowing golfs it will work again when its dry. :?
Thanks and i will give it a go.
Rob ;o)
Audi A4 1.9TDI - Gone
I wouldn't recommend cleaning it with a pressure washer again use gunk and hot soapy water and then rinse. a pressure washer or steam cleaner forces water in everywhere even past good water seals and can cause massive problems.
Also give it a good run the heat of the engine will help dry it out.
Rob
Robb said
top right of rocker cover where the rocker cover earth strap to bulkhead is( hidden by the air tube to the inlet manifold) seen the picture on your other thread very clean
Rob
yeah that engine in the other post is Walts and it looks stunning!
so the earth strap goes to the rocker cover but where does it come from?
Steve
Steve
You see my clock tells its own time!!! i once managed 3 miles at 200mpg and AvMPH of 87, i didnt even get to 40!
Sometimes I wish my MFA didn't work as it distracts me from the road and I can't resist pushing buttons!!!
Rob
