mfa again
(In Topic #72782)
mfa again
I think I best go now
mk1 silver campaign totally standard lowered on coilovers magic tree vanilla
Just had a full outer body restore
The flashing red light, if its in the water temp gauge its to warn you that the car?s over heating or low on water. Check the contacts/wiring on the sender on top of the water expansion bottle. They sometimes trick the light into thinking the water is low. Is it running hot? Does the gauge read higher than normal? Or it could be 1980s VW electrics playing tricks, my brothers 1300 MK1 Driver spent months flashing its red light but now OK.
The reverse lights work off the same switch as the economy gauge, nothing to do with the MFA. See the other thread about replacing with a MK11 version. Also check the wiring connector where the main loom joins the mini loom to the gearbox switch.
Use a multimeter to check if 12v is getting to the horn.
Hang on in there
:wink: :wink:
