main beam light probelms
(In Topic #103358)
was hoping that you would be able to help me.
I have a mark 1 golf g reg.
it has not been on the road for a couple of years and have just had a mot to get th emk1 on th eroad.
The mot failed for a cople of reasons.
firstly and i think the importat thing is the switch that operates the headlights.
when i switch the lights to position 1 the sidelights come on and also the dipped beam.
when i put the switch in position 2 then i get a full beam as if i am flashing some1……. the flasher stick does not work function at all and am confused what is happening.
I also failed because i have no fog light at the back of the car and having looked at the lights at the back i have ealized that there is no fog light? or is there?
you seem the right person to ask and hope you can help
HEADLIGHT PROBLEMS
I HAVE CHECKED THE FLASHER STALK AND IT LOOKS FINE TO ME, NOT SURE WHAT I SHOULD BE LOOKING FOR. IT DOES OPERATE AS NORMAL IN TERMS OF MOVEMET BUT IT AINT DOING ANYTHING.
WHAT SHOULD I BE LOOKING FOR?
I DID HAVE A SIMILAR PROBLEM WITH MY INDICATORS WHERE THAY ALL USED TO FLASH BUT SOLVED THE PROBLEM AT THE BACK OF THE FUSE BOARD,
I have looked at the wirng diagrams and have noticed that there is no wire going into the back of the fuse board position at position "m" .
i think this is the problem but not sure
