Main beam flash
(In Topic #78149)
Main beam flash
Don't quite get what you mean - The Mk1's have proper flashing? Unless it is an early one and they are different?
My Build Thread
My Build Thread
yeha said
Sat in the car, pulled the stalk and I get a click before the lights flash. If I then turn the lights on, I'm straight into main beam.
I'd go with AL_mk1's suggestion and clean up all the contacts on the stalk. From what I remember when mine was apart, most of the terminals are faily easy to clean when you take the stalk off the car. See if that improves things, if not might be looking at a replacement stalk if you want to get that bit of it working. It is right though, the lights should come on before the stick clicks into locking on main beam
Mike.
1983 White cabriolet GTi
Big
