main beam doesn't work
(In Topic #91598)
basically my main beam does not work? side and full beam works fine and dash lights however the main beam does not work? any ideas all fuses r ok as far as i can see. MOT soon so i cant bodge it.
ed
Have you got another light switch you could try if fuses are fine.
also does full beam latch on correctly or just flash.
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=30562
1988 1.8 carb Golf Clipper
ive tryed a new switch no joy!!!! n e more ideas befor i spend all tommoro goin thru my wire loom looking at annoyin wires seeing which 1 has broke lol. thanks
Member 125 - 2005
is there any way of testing relays? or just replace with a new/known working one?
thanks
seen a few mk1's with this problem now,
give the electrical connections on the back of the stalks a wiggle, see if that sorts it, if so its a crap connection so do this……
disconnect the connection blocks from the backl of the stalks, take off steering wheel, take out the 3 small pins to remove the stalks, they will then come off in 2 pieces.
give all the electrical connections on the back (where the wiring plugs connect to) a thorough clean with a fine bit of sand paper and put it all back together
10-15 min job and you should now see where your going in the dark
thanks again for all ideas
x
i took apart the stalks and cleanded them they looked really grubby. put it all back together but it didnt work so i had a good poke around and it was just some dodgy wiring where a wire has broken so replaced and now works fine thatnks for all your help.
