List of electrical problems with new car..!!
(In Topic #87657)
Rear lights intermittant with the occasional front light blinking off?!
Instrument panel not lit, although the road lights button seams to glow, could that be glow or light?!
Cheers guys, love the new car just a few issues to sort!
1982 1.8T-20v-GtEfi. K03S. Megasquirt. 16v Servo + MS. Relayed lights. Mk3 Wiper Motor… Getting too Reliable!
With thanks Eddie-Toyotec, Ben-Bens_cab, Brian-Broke and the Mk1 Owners Club! 211Bhp, should get 250 on next map!
wiring
take the dash out ( you have to anyway to check bulbs behind intrument panel ) and check all the connectors including the eatrh terminals next to the fusebox and the connections on the fusebox itself cleaning and tightening where needed
hope this helps
83 1.5 gl all black sold
86 1.8 gti cab all black light mods. restoring
87 1.8gti cab standard helios blue. daily driver
91 1.8 auto cab gold clipper. breaking
The headlight probs could be because of corroded wires or terminals to the headlighs themselves. Pull the plug off and have a look.
Oh and obviously you know about the dimmer switch for the dash? Next to the headlight switch.
<a><img></a><a href="Login to a private Photobucket.com album
Re: wiring
what? dnt take the dash out just take the panel off the front of the heater cotrol
i think when i went through the receipts and history of the car its had exactly all that work already done, lights changed, looked at, dash out for bulbs etc so im a little bit scared, earth hasnt been checked and could deffinatly be the source, it was repainted so possible corrosion could of got under these earth points..
Awesome little car though, dead chuffed. As soon as i got onto the motorway i got a nod from a bloke driving past!!
I had a very similar list of faults to yours when i bought mine about six weeks ago. In the end all the electrical faults were down to a selection of loose or old and dirty connectors ( dont bother cleaning them just cut them off and replace with new ones). I tried to clean them up but they d just become loose so replacement is best.
Rear lights was the earth inside the back panel, recently painted too. Replaced the earth ring and scratched back the paint to give a better contact. Another problem was the earth connections behind the fuse box, again loose connectors wanted replacing there.
Work on one thing at a time and fixing one seemed to cure some others too. Its a bit daunting taking them all on together but as you pick them off one by one it all seems a little easier. Good luck mate.
Heater switch, the mystery is that you will turn the switch and the revs die slightly so you know something electrical is putting strain on the alternator. That one will have to wait for the mo!
EDIT
Im looking at the lights switch and ive found a grey wire loose, with two ends, one goes into the switch block and the other presmably goes into this big black block jointed onto a black wire with a white stripe. Where abouts does is this grey wire ment to be in the switch block!!?
Owner of:
1988 VW Caddy 1.6
www.vwcaddy.com
1988 VW Caddy 1.6
www.vwcaddy.com
Rear
Fuse's earth
Any others?
www.gsfcarparts.com
think it was about ?60 but dont quote me on that.
Lights, the rear lights are still intermitant, the earth is fine in the boot, checked with a multimeter and cleaned. Cant find the fusebox earth!!?
Ordered a new idle control screw but its got to some from grrrrmany so will have to sit like a melon in traffic at 2k revs, managed to get it just down to 1k revs and put her on the AFR, she was running at 13.2:1 so changed it to 14.5 (thought id stay the richer side of 14.7..!!) and she has a little more grunt on wide open throttle, shouldnt last long as i think ill be doing the 20v t route in the summer !!! http://www.qpeng.com/ have been an awesome help!
