Lights switch on mfa and rev go off??? Help!
(In Topic #123914)
Hi all
When i switch my lights on my 1991 gti cabriolet the rev counter needle drops right off as if its not connected and the mfa display goes to a blank screen when i switch lights back off everything goes back to normal but the time is lost,the main beam light is on when its dipped and it goes off when main beam is selected any idea's
Thanks Steve
Just tried it again and it seems when i dim the display right down the revs rise and the mfa clock comes back on got to be something to do with this?
Thanks Steve
Life Member
Brown earth lead to the rear right of the rocker cover block will have come off. The brown earth lead conmes out of the loom from under the servo area.
I'm going to make this advice a sticky cause I type it out 3 times a week at least!!!
Cheers mate i had a quick look and it looks like its still connected i will take it off tomorrow and clean it up,i have noticed that when main beam is on the oil light next to it stays on is this that same earth lead cheers Steve
I had the same issue with mine. The earth was connected and it ended up being the actual switch on the dash. Replaced it and it all works fine now.
Jamie
Jamie
Its not that earth lead,any more ideas please before i resort to taking dash apart to replace light switch,are there any relays i can check any help please!!
Thanks Steve
Thanks Steve
Thanks Steve
dont know much about the electrical problem but it takes 2 mins to get you light switch out. with a small flat screwdriver,you dont ned to remove the dash.
carefully flick off the fascia over it and you can get it out..
PNERivage
Cheers mate got the switch out no problems as you described!
paneristi312
I owe you a pint mate
I took switch out and bent the dimmer sliders prongs so its the switch as its spot on now mate,going to get a new switch tomorrow
Thanks again mate
paneristi312
Thanks again mate
Well i got another switch and its still happening but by putting the old switch back in with the contacts bent apart so the dimmer for the dash light doesn't work all is well except there is no dash lights.
Any more idea's anyone?
Thanks Steve
Thanks Steve
Thanks Steve
Was the switch you got in full working order? I had 3 before I got one that didn't have the same problem.
Jamie
