lighting problems +
(In Topic #97787)
lighting problems +
I've just finished doing a 2.0 conversion on my 89 gti cabrio i also had welding done to front panel and clutch hole in bulkhead and front panel/slam panel painted.
After it was all done the car started no problem and runs super, but my right headlight is on main beam all the time even when the fuse is removed, also no front or side indicators, washer pump works when indicator switched left, horn makes a noise in fuse box, no front lights, hazards only work rear indicators but the front side lights flash aswell, i think thats about it LOL
I've checked the wiring close to where the welding was done and it all apears fine, im thinking this may be a earthing problem but don't know where to start, the earth strap to gearbox is connected. Do the head lights earth through the holding screws as there is new paint on there which may be stopping it earthing?
Thanks Steve
1982 1.8T-20v-GtEfi. K03S. Megasquirt. 16v Servo + MS. Relayed lights. Mk3 Wiper Motor… Getting too Reliable!
With thanks Eddie-Toyotec, Ben-Bens_cab, Brian-Broke and the Mk1 Owners Club! 211Bhp, should get 250 on next map!
