Light switch cuts power!!!
(In Topic #79154)
When I switch my lights on, I lose all dash info? MFA, Tacho etc. Switch them off and it all works again, except MFA has reset itself?
Any ideas why it's doing this?
Thanks Steve
teammonkey
Life Member
If its not connected then loads of things go wrong with the MFA, lights, rev counter etc.
Dan
Dano said
Have a look at the earth lead in the engine bay. Looking from the front, into the bay, locate the rocker cover and then the rear right nut on the cover. there should be an earth strap that goes to the bulk head. If its not there have a good rummage around lower down in the bay as it may have dropped down.
Dan
Ok that sounds like a great idea, only thing now is it has 16v engine in it Guessing I'm looking for brown cable in origianl loom, any idea what cables are attached to same loom etc???
teammonkey
Cut it short from dash loom and earthed out above dash rather than going to dizzy, all works ok now.
Can't see any problems by doing it this way can you? Not got dizzy anymore running electronic ignition.
Thanks Again Steve
teammonkey
Life Member
Glad it helped point you in a right(ish) direction.
Dan
I'm curious to know - does the temperature reading on the MFA change when you turn the engine off? A lot of posts talk about the temperature changing by several ?C between engine on and engine off. Mine stays the same, but then the return wire goes to the rocker cover. Big
