Light problems.help please.
(In Topic #79797)
cheers :wink:
it was the earth from the rocker cover, theres 2 on mine, 1 was holding on by 1 thread, i rewired it and all now works fine, took 10 mins
theres a list of earth points in the electrics archive thats very usefull, rule them out one by one,
easiest first
rebuild in progress....
check by the door hinges, theres an earth wire in the rubber housing there mine were cut through from rubbing, check your boot theres a couple, and your rear window heater circuit, it earths passenger side at the back of the boot, defo chk the rocker cover theres 2 there,
those are the easy ones,
and i bet its one of them, they seem vulnerable to me, ive only a little bit of xperience on this
all the knowledgable guys are out in there perfectly running golfs!!!
earthing points
harps said
Got most off it working now but,problem now is,Indercators are fine on there own but when you aply the brakes the right one flashes realy quick,any ideas would be great,got the mot in a week.
cheers :wink:
From “Light problems.help please.”
I've the exact same problem, anyone remember this thread and what the cause of the problem was. Going slightly mad with it at the mo.
