Left Hand indicators only!
For some screwed up reason my right indicators have stopped working. All fur bulbs work and flash correctly via the hazard switch, but nought when indicating right…
Any specific ideas?
Dave
Mk1 Golf 16V Conversion FAQ Zip, now located at in the Forum WIKI section: http://vwgolfmk1.org.uk/index.php?page=cedi&type=misc&id=42%2F26%2F3
Isnt there a seperate fuse for each side of the car? I can't check at the moment but that could be a good starting point.
dave,
Probably the indicator stalk or wiring around the column.
Crazyquiff's Mk1 Golf Parts Emporium
www.golfmk1.co.uk - you know you want to….
My bro had a problem like this, hazards worked fine but indicators went dead slow, or sometimes hazards worked fine and indicator would just stay on. Turned out to be the relay.
Mk1 Golf GTI 83 Y reg in Lhasa green
Rear disc conversion
Lowered 20mm
14" Campaign Pirrelli P Slots
Have checked fuses, theyre fine.
Its doing all manner of strange things at th momment, leaning me towards the stalk, Will go for that first and then try relay.
Cheers Guys,
Rich, will be in touch  :y:
 8)
Is it the relay that controls the speed of the flashes?
Cos my hazards work at the right speed, but my indicators flash on too quickly with a too long gap between, if ya know what i mean.
Would a new relay solve this?
Phataz that was exactly my problem.
Until tonight, where i appear to have messed it up even more.  Change indicator stalk and now neither indictor works. Hazards still work fine though. :banghead:
All working now!  apart from double flashing indicators and both side lights coming on instead of just the one for parking lights.
For this try a new relay , i had 2 Hella , 1 flashed fast 1 flashed normally , 4 way same for both .
