LED upgrade to interior lights
(In Topic #140127)
How did you go about it?
Do they dim/ vary in brilliance?
J
COTM Team
i used a 12v led strip, think i may have some left if its any good, pm me it runs 12v you just need to solder positive to 12v and negative to earth on the bulb holder, takes about 10 mins of soldering and a couple of hours for glue to dry i used epoxy resin, the sticky strip is buggered now
hope helps
chris
Be wary of the polarity when you fit it, leds are fussier than incandescent bulbs about current flow.
COTM Team
chinocchio said
Like aircooled said, search ebay for an led festoon bulb, 44mm I think.
Very true, they are fussy but on the bright side (no pun ) if you do put it in the wrong way round, it wont hurt it whatsoever
chris
No fireworks, they just won't work if they're the wrong way round which can easily lead to the assumption that you've bought a dud.
COTM Team
COTM Team
