KR conversion
(In Topic #99557)
KR conversion
iam using the KR engine loom and caddy lighting loom with the caddy fuse box. all plug and play yeah yeah yeah lol (day 2 and still not close)
but without the ISV on hows it goin to run ? any way of controling the idle with what i have?
thanks.
i have removed the cold start system from the loom and bypassed it on the engine.
one blue one on the front of the inlet
brown one under the dizzy
and a grey one under the fuel lines
stay with me,this is my first vw conversion
thanks ,rik.
caddy_rik said
also. what do the 3 multi plug connectors do on the side of the kr engine?
thanks ,rik.
How many pins in the multi plug? AFAIK the ones to the various components on the engine can't be identified by colour alone, because the colours are used more than once. The ones on the back of the fusebox (the big multiplugs) ARE colour coded.
I meant not to use the KR ENGINE loom (no such thing really, anyway), but to simply adapt the Mk1 stuff to the KR engine.
heres the blue one. the green wire goes round to the brown one under the dizzy. all three of them are the same size
and you can just see the grey one at the top of the pic
brown = thermo time switch
grey = warm up regulator.
The Mk1 injection already has these components (since its K Jet too), albeit in different places. You can simply reuse the existing loom and rearrange the wiring.
and i havent got my fuel pump yet so i havent wired it up or bough tthe relay for that yet.
just need to sort the rest out first
caddy_rik said
the multi plug to the fuse box you mean? yes i am told they are
Who by? I'd be checking myself, if I were you….
ihave just fitted the caddy loom back in as its the same as what i made the kr loom into..
i have got the ecu loom sorted and throttle.
but again i have three plugs like the one i posted a pic off. all 2 pins.and like you said they arent colour coded this time.
thanks.
caddy_rik said
right i have been playing again and i have been so stupid..
thanks.
Where do you have the 3 plugs, on the caddy loom? Or the KR loom? And if you have make the KR loom the same as the caddy loom, how come it has 3 extra plugs on it? Or do both have 3 extra plugs?
Or is it the other loom, there's 2 which go towards the engine bay?
etc
and the rest is all 1.6 petrol caddy loom.
when i say i made the kr loom same as the caddy one, i mean once the cold start bit is removed thats all you have left
and yes i still have three plugs on the caddy loom i forgot where they went on the caddy engine though. so not sure where they go on the 16v engine.
is this because its the 5th injector and obviously caddy was carb so its not needed?
caddy_rik said
if you look in the pic the blue connector has a green wire from it. the caddy loom hasnt got a green wire to any of those three connectors.
Has the caddy got the connectors too? And if so, what#s the colour code on each. Since they're 2 pin terminals….they'll have 2 wires and 2 colour codes each.
1. black +black yellow pin stripe
2. black +black brown pin stripe
3. brown + yellow red pin stripe
caddy_rik said
just been out and checked
You'll need to find a wiring diagram for a caddy and find these wires on it then. The colours aren't in an 1983 injection car, which is the only wiring diagram I know.
my caddy is a 89 1.6 petrol if you find any wire lists with the pin numbers let me know !
