ISV + WUR wiring for dummies (me)
(In Topic #77678)
Could someone please advise me of the correct way 8O
Ta.
www.vwcaddy.com
warm up reg has 2 wires
The voltage supply to the regulator is from the fuel pump relay, because if the ignition was on without the engine running, all enrichment would be removed as the bi-metalic strip would be heated prematurely and the driver would not benefit from the cold engine enrichment . See…..
Domain parking page
The ISV
:dontknow: What do you mean ? Is it a 16v bit ?
Cheers…………
ISV/air valve, all details i needed in the link above, I'm on a learning curve this week.
Thanks again.
www.vwcaddy.com
I'm not sure how a mk2 engine is set up but I'm sure its similar. The digifant setup has an ISV but its larger and cylindrical in shape.
Not sure how they are wired.
Cheers,
Ross
