Instrument binnacle lights
(In Topic #128240)
Tim
You are right there is only 3 illumination bulbs for the dash binnacle. I asume you have made sure the illumination control under the head lamp switch is on max. Have you checked the condition of the bulbs if they are old the may have gone black they may benifit from replacment bulbs. they are 12 volt 2 Watt bulbs with a built in bayonet fiiting like the ones on Ebay http://cgi.ebay.co.uk/VW-GOLF-JETTA-MK2-DASH-BULBS-SET-4-C116-/200527163658?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2eb059b10a
Hope this helps
Ian-VW trained technician
Suck, Sqeeze, Bang, Blow The Otto cycle
1983 Golf Driver, MK1 golf owners club Best Standard Hatchback winner 2009,2010 & 2011
1980 Golf cabriolet GLI
2002 Golf GT TDI 196BHP AND 455Nm torque
I bought a set
set of 4
On my mk1 driver 2 light up the speedo and rev counter an 1 lights up the digital clock
Lights????
Can anyone help me on a similar issue.
Hope I haven't highjacked the thread :redfaced:
I've bought a set of these 2w bulbs as the original 3 in the cluster had blown, but I just cant seen to get them to work????
No lights on the clocks what-so-eva !!!!
Ive fitted 2 sets now and they just won't illuminate.
Any ideas????
Thanks in advance…
are the other lights on on your dash?
if they are I expect there is a problem with the pcb on your clocks..
do you have an MFA? and does it work?
Tony
MFA works fine.
Other lights on dash? If you mean red temp light, blue high beam light, oil light and indicator green light - yes they all work fine.
No heather panel illumination either???
Is there any way I can measure the voltage acroos the strip/ contacts that the little bults twist onto?
:dontknow:
the bulbs would not light even thought there was voltage across the strips. I ended up (until I got new clocks) with soldering the bulbs onto a harness clamped on the the dash illumination circuit
Sorry, I didnt mean the binnacle lights I mean the heater and cig lighter surround.
if you put you lights on and nothing else is illuminated inside the car. It could be the switch I suppose
Could do with rubjonny jumping on the post
where are you rubjonny?
(you could pm him?)
Other than that make sure the filiments you are fitting are definately okay with a 9v batter or something, then make sure thay are seating correctly in there holders and are making connection to the back of the panel properly.
If you still not getting any joy it sounds like a wiring fault, on either the earthing side or live feed.
06 Audi A3 (Wifes daily)
Thanks for the advice chaps.
I'll keep you posted on my findings…
...AND THEN THERE WAS LIGHT !!!!!!
I'll run through the sequence of events….
Clocks out again.
3 x 2w bulbs out again.
So empty dash again….
I then checked all the pin-outs on the plugs.
Gave em a good shake to release any fluff (technical) :wink:
Checked the usual earth on the rocker cover.
Now….in the meantime I'm replacing the blower motor in the plenum.
The 2nd hand motor arrived yesterday so i was fitting that whilst it was dry.
After installation and refitting dash clocks/heater/switches, I did the checks…
Key on position 2….heater switch on…heater blowing fine.
I then turned her over and sat at idle enjoying the the fact the heater was working 8)
I tried the lights and turned up the dimmer thumb wheel and hey presto!!!!
Although a bit dim, they work !
Gawd knows what i've done !!!!!
So a fully functional heater and lights on the dash in one day - bonus !!
Do I have to take the whole dash out to get access to the bulbs, or is there a way of avoiding this?
If you have to take the dash to bits, then I'd advise being very gentle with all the trim panels, if it wont come off then dont force it, chances are you've missed a screw somewhere. Most of my dash is held on with bits of blue tack now, as I've had to learn the hard way where all the little hiding screws are!
I have had mine out many times…
This is all from memory so forgive me if slightly wrong..
be gentle and flick the switch fasicas off from roung the hazard waring light and headlight switch with a small flat screw driver.. try not to dent the plastic
this with reveal two screws
Take radio out and if somebody has been kind they may have cut a hole out in your radio cage to get to the screw otherwise you will have to take your cage out too.. to reveal the screw
look at your binnacle on the underside of the dash and I think there is one screw there too (* Edit there are 2)
pull the 3 heater sliders out and keep safe
there maybe one other screw around here some where
unscrew the revealed screws all the Dash Fasia should now come away from the dash with the switches attached. keep an eye open for any bits sticking where I may have missed a screw
Carefully remove each switch and reattach the other side of the fascia.. the hazard warning switch is a bit tricky and is live
remove the heater panel bit tricky (hopefully it will be obvious) ..
with the fasica off you can now see the binnacle screw (one either side) unscrew and the carefully pull the binnacle forward from the top
you may have to reach round the back to unplug the speedo cable and a few other bits the main plug a rubber tubing and one other
Hope this helps.. but have a search on the forum, I am sure there are some pics somewhere
Tony
And I should know about the hazard warning switch connections being live !!!!
3 fuses later and mine was all back together
As I went out one evening to fill the car up with petrol, the dashboard started smoking as soon as I put the headlights on! I think this was because I had reconnected the cigarette lighter the previous day. The light switch and wire (grey/blue) is totally fried, so I didn't get a chance to change the bulbs.
My question is this - can I just get hold of any 15amp wire to replace the fried one? I've no electrical experience, so don't want to put in an incorrect one and fry the whole lot!!
Any advice greatly appreciated
