Indicators
(In Topic #134201)
Indicators
When i try to indicate either left or right the green light comes on solid and also brighter but the indicators on the outside of the car don't work.
If i use the Hazzard warning lights all of the outside lights flash and the green dash light flashes as it should
Re: Indicators
I have this problem! i have tried to change the relay, have also changed the fuse box and fuse 19 is all good,
whats wrong?? where could the error be? :dontknow:
sorry for my bad english
-Daniel
rubjonny said
pull the dash fuse for 30 seconds
hi fuse 19? with ignition on or off my 1988 gti cab is doing the exact thing
tom
rubjonny said
its fuse #3 for the 88 cab, ign on or off makes no difference
cheers mate ill try it tomorow
tom
ive reset the dash cluster with no joy, im thinking it my be a dodgey earth problem. has any body got a wiring diagram the engine and dash to download????
tom
rubjonny said
the dash earths to the cylinder head, its one of the brown/white wires. this wire runs from the dash brown/white wire to a spade connector behind the fusebox, then from there to the head
top man i think the wires are the wrong way round in the engine bay some one has
been messing with it and its a right mess, ive put that earth wire on the
oil pressure switch on the side of the head and the oil wire to earth,to the rocker cover.
That would deffo explain my dodgey indicators and oil light coming on and going off lol
Will swop them round monday
tom
